Chris039
3 years agoWhich folder contains the source code for Nios II built in function
In the bsp generated using Nios II, there is one file <bsp folder>/HAL/inc/io.h. You may easily find this in the hello world design.
In line below,
#define IORD(BASE, REGNUM) \ __built...
- 3 years ago
Hi Chris,
Sorry about the bad news. Unfortunately after consulting the engineering team, we are unable to provide the definition on how to use the built in function and the source code as it is private and confidential. However, do feel free to use the macros which is the IORD or IOWR that calls the built in function.
I will set your case to close-pending if I do not hear from you the next few days. Thank you.
Kelly
KellyJialin_Goh
3 years agoHi,
You may check out this link https://www.intel.com/content/www/us/en/docs/programmable/683242/current/nios-ii-custom-instruction-overview.html and download the pdf, check out chapter 3.2 Built in Function and User defined Macros. I believe the file you refer to is the system.h for custom instructions.
Kelly
