Which folder contains the source code for Nios II built in function
- 3 years ago
Hi Chris,
Sorry about the bad news. Unfortunately after consulting the engineering team, we are unable to provide the definition on how to use the built in function and the source code as it is private and confidential. However, do feel free to use the macros which is the IORD or IOWR that calls the built in function.
I will set your case to close-pending if I do not hear from you the next few days. Thank you.
Kelly
Hi Chris,
Could you kindly check out this link:https://www.intel.com/content/www/us/en/support/programmable/support-resources/devices/ips-nios2-ide-tutorial.html and download the source files(any version works fine) and unzip them. Unzip once with command tar -xf on linux environement or unzip twice on Windows environment.
Kelly
