21 years agoWhat's the burst length of SDRAM in Nios II?
The SDRAM Controller in Nios II is just a big black box, almost no details is supplied in the datasheet come with Nios II. For example, what's the burst length of every read or write to the SDRAM...
21 years agoYou're Welcome RM!
I've been struggling to port proven code from a 55MHz Motorola Coldfire to a 75MHz NiosI/II for months. It's somewhere between 30% and 50% of the performance on the NiosI/II. I believe the lack of a single instruction to read/write *and* increment/decrement the address all in one clock is partially to blame. On Coldfire the *pointer++ can map to something like LDW g1, (addr)+. Super fast sram or even cache is not going to help when you need an instruction to do the load or store and another (at least) to increment. I see in several of the .s files that typically there is a LDBIO r4, (r11) followed by a ADDI r11, 1 to increment. Need to add postincremental adressing i.e. LDBIO r4, (r11)+. Pre/Postdecrementing is nice too LDBIO r4, -(r11). Hopefully this is available at least if I code by hand. I was wondering if I could do something with loops I know I can unroll. for(i=0 ; i<max_i ; i+=4) { LDW r4, 0(r11) //do stuff with r4 LDW r4, 1(r11) //do stuff with r4 LDW r4, 2(r11) // ditto LDW r4, 3(r11) } Clumsy though. Any clever ideas? Ken
