21 years agoWhat's the burst length of SDRAM in Nios II?
The SDRAM Controller in Nios II is just a big black box, almost no details is supplied in the datasheet come with Nios II. For example, what's the burst length of every read or write to the SDRAM...
21 years agoTo Kenland & Clancy:
Thank you! I have got the two ideas from the Modelsim Simulation Waveform: *The burst length of @ltera's SDRAM Controller is 1(just like what Clancy mentioned), maybe we cannot modify it while we can do such thing to DDR SDRAM Controller. *The SDRAM can realize almost one work per clock when the controller sends "Read" commands consecutively(But I do not know how to instruct it to do so). From the waveform of example from AN351, 8 words can be read from SDRAM consecutively. Just like what Kenland has done, I tried to use "pointer++" to get consecutively located data from SDRAM, the simulation result disappointed me down to hell: a word would return from SDRAM every more than 5 clock cycles(I did not calculate the exact cycles). During this workday, I will try dma. Thank you, Kenland & Clancy!
