13 years agoWhat is difference and relation between gigabit transceiver and PCIe?
When I review some documents, there are two terminologies: PCIe and gigabit transceiver. In many cases, these two appear at the same time. Could somebody help me understand what is difference and rel...
13 years agoRemember PCIe is a networking protocol, not a bus protocol!
I PCIe write is sent as an hdlc frame containing the address and data (typically upto 128 bytes worth), when the target has completed the action it sends back response packet. This means that there is a moderate amount of 'software' (usually a big state engine) associated with the PCIe interface. This is also why, although PCIe is high throughtput, it is often also high latency. This matters when the cycle is expected to be synchronous - eg when a cpu is reading a device register.
