10 years agoWhat are difference between NIOS II processor And DSP processor
hi friends can any one brief the difference between NIOS II and any other DSP processor
10 years agoNios is based on MIPS architecture and it is totally different from DSPs. If you need a high performance Digital Signal Processor, you may use an external DSP or implement your processing inside FPGA using hardware logic (not software-based Nios application). Architecture of Nios is for embedded applications, not DSP applications.
