16 years agoWeird Ethernet problem
Premise: I don't know if this weird problem is related to TSE, sgdma or Nios code. Please help me to identify, or better, to solve it. I'm using Nios II with tse mac and National Semi DP83640 p...
16 years ago --- Quote Start --- Is the link set up in half duplex mode when you are using a hub? In that case could it simply be that you have collisions? --- Quote End --- No, the link is always in full duplex mode. As I said, the weirdest part is that the problem arises when rx and tx are not at the same time; indeed I don't see this anomaly if I receive the frame exactly when I'm transmitting another one (i.e. when rx_en and tx_en tse mac signals are both active). I can now reproduce in a deterministic way these conditions: - rx and tx contemporary: OK - rx delayed about 15us from tx: OK if tx rate is more than 1 every 50ms. If I use a higher tx rate, some frames are lost. In this last condition, if I transmit a frame every 5ms and the same frame loops back after 15us I obtain this cyclic behaviour: frame are transmitted correctly for about 1s then stop for about 0.5s, then again it works for 1s and so on. At the mac-phy level I don't see any anomaly, although I did't analyse actual data, but only checked the presence of tx_en and rx_en signals. From this last result I think that there could be a problem with mac clock timing. This is a sort of frequency beating behavior. Regards
