16 years agoWeb server example on Cyclone III dev board
Hello, I'm trying to run the web server example on the Cyclone III dev board (where the FPGA is connected to a Marvell PHY). Some things work, but some don't: I see on "Nios console" ...
15 years agoHi Eliben,
What version of Nios II EDS software are you using? Are you creating Web Server from Project Template? If I'm not mistaken, starting from Nios II EDS v9.1 or v10.0, there are two versions of web server from Project Template. One is Web Server and another one is Web Server (RGMII). The latter will be used. You might probably encounter such error if you used Web Server without RGMII. To Suma, You need license sd card controller. It is a custom component provided by Altera's 3rd party i.e. SLS. Please contact them for requesting license:- http://www.slscorp.com/pages/ip_sdhostcontroller.php However, you may also want to disable this component since web server doesn't require it. In top level, you need to comment out all the sd card controller related codes. Regards, Caridee
