15 years agoWant to determine Altera Development Board SOPC Recipe equivalent?
hi, I have a Altera GX Development board. I am using Quartus 9.1 SP2. I am writing my own Windows driver which needs to do DMA transfers from the device memory to PC Host. I won'...
15 years agoHmmmmm...it looks like the Altera Demo is doing DMA transfers onboard, and not to PC Host, thus I can't get comparable figures.
I can get 30MB/sec going from onboard DDR2 to PC Host now. I've played with the various bursting options as follows: * I set 8 beats in the DDR2 memory settings * 8 wide read burst signal and 8 wide write burst signal in the SGDMA engine settings * data width 64 for Data and Error Widths (but I don't think that applies when you are bursting....only for non-bursts) * use the High Performance II Memory controller, with Local Maximum Burst count 8. The descriptors are put into the onboard DDR2 memory. I am NOT enabling bursting on read descriptor read master. Maybe I can get an improvement by either enabling bursting, or put the descriptors into onchip memory ? but it would be very small won't it ? ...however, I would like to find out what the theoritcal/pratical maximum I could achieve with the SGDMA...between onboard DDR2 and PC Host.....anyone have any ideas?
