20 years agoVolatile... or is it??
Hi there,
I just wanted to save you guys some gray hairs when working with pointers to your hardware in a kernel module. I had a module with a volatile struct pointing to the registers of my custom peripheral on the avalon-bus. All worked fine untill I got strange errors when changing values "fast" (each millisecond). Values would not be updated correctly... Even though I declared everything volatile, it wouldn't work when I wrote and read data every milisecond. When I changed my delay 'till 50ms or higher everything worked like expected. Changing the volatile struct with the corresponding inl and outl functions solved my problems. I Hope I can save someone some time....2 Replies
If I remember correctly, the volatile keyword does not cause the Nios II compiler to generate code to bypass the cache. That could be the source of your problem. I think there was a thread on this a while ago in the general software forum, you could try searching for it.
Dennis Scott Microtronix Datacom - Altera_Forum
Hi All,
> If I remember correctly, the volatile keyword does not cause the Nios II compiler to > generate code to bypass the cache. Correct. And it shouldn't ... the presence of a cache (or lack thereof) has nothing to do with compiler optimizations that may affect the stability of the object. With gcc the volatilie keyword traditionally boils down to accessing the object each time it is referenced ... nothing more. If you're accessing hardware registers, do yourself a favor and use the HAL macros -- that's what they're for. Regards, --Scott
