16 years agoVhdl question
I come on this pice of code: SIGNAL clockticks200k: INTEGER RANGE 0 TO max200k; What dose Range stand for?
16 years ago --- Quote Start --- I come on this pice of code: SIGNAL clockticks200k: INTEGER RANGE 0 TO max200k; What dose Range stand for? --- Quote End --- The word range is used here to constrain the signal clockticks200k to the range 0<=clockticks200k<=max200k. If the value that clockticks200k ever evaluates to something outside of this range, a simulator will assert an error telling you so. If the signal were declared: SIGNAL clockticks200k: INTEGER; no such checks would be performed. Range constraining is a good practice if you know the bounds of the values. It provides a free assertion for you in your VHDL code without having to actually code an assertion.
