15 years agoVery confused rank newbie looking for advice
Hello All: I have been evaluating various ucontrollers such as the Atmel AVR line, the huge ARM family and PIC. In recent years, all my dev work has been high level PC based. The advances in em...
15 years agoWith care you can get the nios to execute very small C functions with no external support libraries (you need to set 2 registers then jump to any C function).
Rip out all the caches and run from 'tightly coupled memory' and the cpu footprint is about 2500 LEs - not a lot in the modern fpgas. So the whole thing will be a lot more flexible than the 8051/pic stuff. Not sure I'd want to run something as big as Linux (or even a normal embedded os) on the nios though. But for a bare board, run some code for a small app it requires a lot less hardware setup than the SoC systems - partially because the hardware config removes a lot of the stuff that the software would otherwise have to do.
