17 years agoVerify Failed in Nios II
I keep getting some variant of the following message: --- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x01 Processor is already paused Reading System ID ...
10 years agoAn update:
The fix is exactly what BadOmen recommended: the reconfig_req pin. Fantastic thread! The example of the tutorial worked perfectly. While I don´t know how to do a fix in a pretty way, I did the following:- I openned a .csv file exported by an example from my board;
- Looking at the .csv file, I found the PLD_RECONFIGREQ_N signal associated with the PIN_J20;
- I established such association with a push_button already planned in the tutorial mentioned in my last message: switcher_external_connection
