17 years agoVerify Failed in Nios II
I keep getting some variant of the following message: --- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x01 Processor is already paused Reading System ID ...
17 years agoUnfortunately my thread from the old forum was lost on this subject but here goes off the top of my head.
- Check your top level connectivity for issues (like dangling nets or signals pulled high or low)
- Check your pinout to make sure you are using the correct I/O in your design
- If you are using the new "Altera ALTPLL" component don't use the PLL lock signal as a filter for reset_n (you'll get stuck in reset). This will be fixed in the next version of the IP.
