15 years agoVerify failed between adress xxxx and xxxx (corresponds to SSRAM adress)
Hi all, I am using Cyclone III NEEK NIOS II development kit. I have created a project by using VIP suite components and drive the lcd on the board which has a resolution 800x480. Then I wan...
15 years agoIt could be a timing problem... do you have timing constraints for the SSRAM interface and does the design meet the timing requirements?
