Verifiy failed between adr.... in SRAM DE2-115 tPad Simple Socket Project
Hi There,
I try to build the SimpleSocketServer_rgmii_0 on my DE2-115 tPad. I could generate the System in SopC and Quartus successfull but in Nios I became this error message: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x014034E0: verified Initializing CPU cache (if present) OK Downloading 01200000 ( 0%) Downloading 01210000 (20%) Downloading 01220000 (41%) Downloading 01230000 (61%) Downloading 01240000 (82%) Downloaded 313KB in 5.3s (59.0KB/s) Verifying 01200000 ( 0%) Verify failed between address 0x1200000 and 0x120FFFF Leaving target processor paused In the System Lib Properties i set the Prog memory and the rest all of sram. In SopC I use the SRAM-Controller from the University Program IP. I try also the IP from TERASIC --> TERASIC_SRAM, still with both version the same error. I run also the Standalone Quartus Prog for program the sof file and then I leave the unlimited window open. I thing that are not the problem. Please help me to find a solution Thanks you Antonio2 Replies
in the attachment you find my SoPc System.
In NiosII I use the template simple_socket_server_rgmii_0 Grazie... - Altera_Forum
Had a similar problem with Terasic SRAM when it is connected to a NIOS II/f (NIOS II/e - no problem). This is because the II/f is much faster (can have transactions one after the other due to the pipeline that it has). I solved this by modifying the Terasic SRAM component in the SOPC system by adding having 2 read waitstates, 2 write waitstates, and 1 hold cycle and 1 setup cycle (this is probably an overkill, you could probably omit a few of the wait states or setup/hold cycles). Now it works without a problem with the II/f (NIOS CLK = 50 MHz). I recommend using the SDRAM for the NIOS, because it is faster and has more capacity than the Terasic SRAM. If you must use the SRAM, change the SOPC component as I indicated above.
