11 years agoVariable Precision DSP in Arria V Devices
hey folks, I am new to altera stuff. I am porting my design from xilinx devices to altera devices. In that process am facing problems with DSPs porting. I am not finding dsp in altera similar...
11 years ago --- Quote Start --- Hey Tricky, You are right, now days every device has many luts. it's not a problem to use luts for adder.But module which m porting is instantiated some 70 times, in that if i take 50 luts for this module(adder logic outside) it will results in 3500 luts approximately.which is a huge number. so to avoid this, m trying to infer dsp so that my design will be optimized. I am targeting arria v devicce. I implemented same way in verilog and synthesized in Quartus II 14.0 (trial version). But it's inferring adder with extra logic only. Thanks. --- Quote End --- xilinx has that sort of dsp blocks but altera doesn't though some blocks contain adders such as those for complex mult. try set your multilipcation as axb + cx1 to use them if available in your device
