11 years agoVariable Precision DSP in Arria V Devices
hey folks, I am new to altera stuff. I am porting my design from xilinx devices to altera devices. In that process am facing problems with DSPs porting. I am not finding dsp in altera similar...
11 years agoWhy cant you just do the add in the FPGA logic?
Even better, just infer the logic from HDL code. *edit* actually, you can just pass C into the LOADCONST port. http://www.altera.co.uk/literature/hb/arria-v/av_52003.pdf If you really wanted to do in inside the DSP block, you could use the 2nd multiplier input with values C and 1.
