21 years agoUsing SDRAM Controller on Development Board
Hi, Does anyone have experience sharing the 32 MBytes of SDRAM that is installed on the DSP Development Kit board between the Nios II and some custom FPGA circuitry? I would like to dedica...
21 years ago --- Quote Start --- originally posted by jhansen@Jul 22 2005, 03:42 AM use a dma to handle the transfer from converter to memory.
then you have a shared resource with two masters, processor and dma.
you can setup priority on each to ensure bandwidth.
12.5 mhz on a 50mhz system gives a load of 25 - 35 % including overhead, that looks ok if hte processore does not use nore than the rest. --- Quote End --- Would the DMA transfers between the A/D and SDRAM be handled by the Nios II core or would a separate DMA controller generated using SOPC act as the 2nd master with the SDRAM providing slave-side arbitration between the Nios II and DMA controller? Also, how difficult is it to create custom FPGA circuitry that interface to the avalon-based DMA controller that transfer data from a the A/D-samples FIFO @ 12.5 MHz and store it on the SDRAM within a specified address range? Effectively you would have the DMA controller master facilitating the transfer between two slave devices (A/D & SDRAM). Brad.
