10 years agoUsing Nios II with PLL
Hello there, so I´m trying to generate 100MHz from 50MHz via the ALTPLL in Qsys and use that 100MHz to speed up the NiosII. Unfortunately its not working... Im Using a 10M16DCF256I7 and ...
10 years agoOK - the project you attached fundamentally works - more or less...
I ported it to a DE0-Nano with no changes, except for the device and pinout. In doing so I notice you'd exported the PLL's reset ("altpll_0_areset_conduit_export") but not constrained it to a pin. So, Quartus has chosen a pin which, I suspect, you're not controlling. So, it's probably pulled high holding the PLL in reset. I connected that to a switch and proved this. Providing the PLL is out of reset (reset driven LOW), the processor boots and "hallo Welt>!Init Phase...." is written to the console. I'm confident (although I didn't try it) that it will work at 100MHz as well. I expect you have the same issue with your MAX 10 project. Cheers, Alex
