10 years agoUsing Nios II with PLL
Hello there, so I´m trying to generate 100MHz from 50MHz via the ALTPLL in Qsys and use that 100MHz to speed up the NiosII. Unfortunately its not working... Im Using a 10M16DCF256I7 and ...
10 years agoHi Alex,
didnt thought of that... But it doesnt work either. The Console is connected via JTAG and the hello world small works without the PLL.... Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused This is the output of Eclipse... For futher diagnosis the whole project is attached. This Project is made with a EP4CE10F17C8N but is also ported to a MAX10 and isn´t working either That you very much.
