10 years agoUser space application access to Hardware. HPS FPGA bridge
Dear all I am a newbie on Altera SoC architecture, so I am trying to run a simple C Userspace application on an Arria 10 SoC (attached file custom_software.zip). The application tries to acce...
10 years agoDear all
I think I have found a begging of a workaround. If you encounter a similar problem like me, here is the process : - first of all enable also the standard HPS-2-FPGA bridge in your Qsys system - follow the same instruction here https://lists.rocketboards.org/piper...st/003260.html then it is possible to access the FPGA bridge from U-boot I am able to run a bare metal application and access the registers. But still not able to do a mmap in Linux userspace (of course with the administrator's rights) Regards Mathieu
