10 years agouse printf in niosii
I can use "printf("Hello from Nios II!\n");" to print "Hello from Nios II!\n " when I run the code on FPGA board. However when I try to print a int, the compiler(Eclipse) doesn't generate the elf ...
10 years agoI solved the question by using bigger on-chip memory. I change the memory from 40Kbytes -> 100KBytes, then I can print the int. Btw thank you for you guys replying.
