10 years agouse printf in niosii
I can use "printf("Hello from Nios II!\n");" to print "Hello from Nios II!\n " when I run the code on FPGA board. However when I try to print a int, the compiler(Eclipse) doesn't generate the elf ...
10 years agoCheck if you are using reduced driver or something to reduce size of elf in the options..
