10 years agouse printf in niosii
I can use "printf("Hello from Nios II!\n");" to print "Hello from Nios II!\n " when I run the code on FPGA board. However when I try to print a int, the compiler(Eclipse) doesn't generate the elf ...
10 years agoYeah, it is hard to guess your problems. I think if you could get the error messages out, Galfonz could point out easily.
A few questions 1. Is this normal hello world or small hello world? 2. Maybe program size overflow? What is the size of the allocated memory in Qsys? 3. Maybe C code bug/typo?
