19 years agoUSB2.0 IP core and uClinux driver
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif I want to use usb camera on altera 1c20 dev board,
I will programme for grabbling images via video4liux API, I will display images in IE through boa web server, is USB2.0 IP core and uClinux driver necessary?if I use ISP1761 could you give me some ideas? thank you! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif19 Replies
--- Quote Start --- originally posted by zhangyan_swpu@Nov 2 2006, 09:43 AM http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif i want to use usb camera on altera 1c20 dev board,i will programme for grabbling images via video4liux api,
i will display images in ie through boa web server,
is usb2.0 ip core and uclinux driver necessary?if i use isp1761
thank you! http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19078)
--- quote end ---
--- Quote End --- You don't need the USB2.0 IP core. You can find link to ISP1761 driver in the UsbHost page on nios wiki. There is a patch for kernel 2.6.17 . The uClinux-dist-20060803 uses kernel 2.6.17 . You should be able to add the driver. I shall prepare a simple interface core to ISP1761 and add the patch, if I could find some spare time. But I have only very limited time.
It's great!
hippo! Thank you very much for your reply! Regards zhangyan - Altera_Forum
Using usb camera on dev board involves hardware and software designs, I want to use USB driver in nios wiki, but in hardware, I am still confused , how to connect USB controller(isp1362 or isp1761) in SOPC Builder in quartus? does usb camera work without USB2.0 ip core? I don't kown how to acess usb camera without USB2.0 ip core. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif Regards zhangyan - Altera_Forum
--- Quote Start --- originally posted by zhangyan_swpu@Nov 7 2006, 10:14 PM http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gifusing usb camera on dev board involves hardware and software designs,
i want to use usb driver in nios wiki,
but in hardware, i am still confused ,
how to connect usb controller(isp1362 or isp1761) in sopc builder in quartus?
does usb camera work without usb2.0 ip core?
i don't kown how to acess usb camera without usb2.0 ip core.
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/huh.gif
regards
zhangyan
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19263)
--- quote end ---
--- Quote End --- I will add and try out isp1761. It may take one or two weeks. I shall let you know the result.
I want to use ps/2 for mouse and keyboard in the linux on the DE2,how i should do?
thank you!! - Altera_Forum
--- Quote Start --- originally posted by liuxiaoping@Dec 28 2006, 04:36 PM i want to use ps/2 for mouse and keyboard in the linux on the de2,how i should do?thank you!!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20254)
--- quote end ---
--- Quote End --- You can look at DE2 demo, or lancelot at http://www.fpga.nl/lancelot.html (http://www.fpga.nl/lancelot.html) There are the PS/2 interface. You still need to write the drivers. Look in linux-2.6.x/drivers/input dir.
What is the DE2 demo?
how i can find that? thank you! - Altera_Forum
--- Quote Start --- originally posted by liuxiaoping@Dec 29 2006, 07:11 PM what is the de2 demo?how i can find that?
thank you!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20284)
--- quote end ---
--- Quote End --- DE2 is a dev board, http://www.terasic.com/downloads/cd-rom/de2/ (http://www.terasic.com/downloads/cd-rom/de2/)
I mean,where i can find the demo of ps/2 on DE2.
--- Quote Start --- originally posted by feng8126@Dec 30 2006, 09:11 AM i mean,where i can find the demo of ps/2 on de2.<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20290)
--- quote end ---
--- Quote End --- http://www.altera.com/education/univ/ip-co...v-ip-cores.html (http://www.altera.com/education/univ/ip-cores/unv-ip-cores.html)
