15 years agoUSB Mass storage without uClinux
Hi, I develop on DE2-70 board. My project use an usb key to store any data. For now, I use uClinux. But I want to remove it, and develop directly on nios2. I only found FAT implementatio...
15 years agoUSB is logically (but not quite physically) polled, multi-drop hdlc. The standard requires very tight timing control for the poll loop (so that fixed speed targets can put fixed amounts of data into each poll cycle).
The poll cycle is normally controlled by the uhci hardware module (or maybe the older ocpi??) which is what the linux driver is probably accessing. I've never looked at that hardware interface :-) it may not be that complicated if you have limited requirements. I'd actually guess that most slaves don't actual verify the poll rate, and that, a simple single target host interface could actually be done with a simple hdlc controller....
