19 years agoUSB host problem on DE2 board
I am trying to access the usb host on my DE2 board using ucLinux. I have followed the steps in the wiki at: http://nioswiki.jot.com/wikihome/operating...host?revision=4 (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/usbhost?revision=4) I can download the image file to the board, however, when I start the terminal to boot the kernel, it hangs while loading the usb driver. Here is the output I receive: [sopc builder]$ nios2-terminal.exenios2-terminal: connected to hardware target using jtag uart on cable
nios2-terminal: "usb-blaster [usb-0]", device 1, instance 0
nios2-terminal: (use the ide stop button or ctrl-c to terminate)
uncompressing linux... ok, booting the kernel.
linux version 2.6.17-uc1 (brian@loafy ) (gcc version 3.4.6)# 16 preempt sun nov 2
6 19:04:45 cst 2006
uclinux/nios ii
altera nios ii support © 2004 microtronix datacom ltd.
built 1 zonelists
kernel command line:
pid hash table entries: 64 (order: 6, 256 bytes)
dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
memory available: 5564k/8192k ram, 0k/0k rom (1518k kernel code, 1020k data)
mount-cache hash table entries: 512
net: registered protocol family 16
scsi subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
net: registered protocol family 2
ip route cache hash table entries: 1024 (order: 0, 4096 bytes)
tcp established hash table entries: 1024 (order: 0, 4096 bytes)
tcp bind hash table entries: 1024 (order: 0, 4096 bytes)
tcp: hash tables configured (established 1024 bind 1024)
tcp reno registered
io scheduler noop registered
io scheduler deadline registered (default)
serial: jtag uart driver $revision: 1.1 $
ttyj0 at mmio 0x81004000 (irq = 1) is a jtag_uart
dm9000 ethernet driver
eth%d: invalid ethernet mac address. please set using ifconfig
eth0: dm9000 at 80900090,80900094 irq 8 mac: 00:00:00:00:00:00
usbmon: debugfs is not available
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: isp1362 host controller
isp1362-hcd isp1362-hcd: new usb bus registered, assigned bus number 1
isp1362_hc_reset:
clock not ready after 20ms
isp1362-hcd isp1362-hcd: irq 4, io mem 0x80900080
isp1362_hc_start:
isp1362-hcd isp1362-hcd: isp1362 memory usage:
isp1362-hcd isp1362-hcd: istl: 2 * 256: 512 @ $0000:$0100
isp1362-hcd isp1362-hcd: intl: 16 * ( 64+8): 1152 @ $0200
isp1362-hcd isp1362-hcd: atl : 32 * ( 64+8): 2304 @ $0680
isp1362-hcd isp1362-hcd: used/free: 3968 128 At this point it stops indefinitely. When I compare this with the output from the wiki, I notice that the following lines appear in my output and not on the wiki: isp1362_hc_reset:
clock not ready after 20ms I'm thinking that I am missing some extra configuration for the FPGA. Currently, I download DE2_NET.sof to my DE2 board as specified in: http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/tryoutuclinux) Does anyone have any idea what could be causing this problem? Help is this matter would be greatly appreciated.
--- Quote Start --- originally posted by kael@Nov 29 2006, 04:34 AM hello,i am trying to access the usb host on my de2 board using uclinux. i have followed the steps in the wiki at:
i can download the image file to the board, however, when i start the terminal to boot the kernel, it hangs while loading the usb driver. here is the output i receive:
[SOPC Builder]$ nios2-terminal.exe nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.17-uc1 (brian@loafy ) (gcc version 3.4.6)# 16 PREEMPT Sun Nov 2 6 19:04:45 CST 2006 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 256 bytes) Dentry cache hash table entries: 1024 (order: 0, 4096 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 5564k/8192k RAM, 0k/0k ROM (1518k kernel code, 1020k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 1024 (order: 0, 4096 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) TCP reno registered io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.1 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart dm9000 Ethernet Driver eth%d: Invalid ethernet MAC address. Please set using ifconfig eth0: dm9000 at 80900090,80900094 IRQ 8 MAC: 00:00:00:00:00:00 usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362_hc_reset: Clock not ready after 20ms isp1362-hcd isp1362-hcd: irq 4, io mem 0x80900080 isp1362_hc_start: isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128[/b] At this point it stops indefinitely. When I compare this with the output from the wiki, I notice that the following lines appear in my output and not on the wiki: isp1362_hc_reset:
clock not ready after 20ms I'm thinking that I am missing some extra configuration for the FPGA. Currently, I download DE2_NET.sof to my DE2 board as specified in: http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/tryoutuclinux) Does anyone have any idea what could be causing this problem? Help is this matter would be greatly appreciated. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19676) --- Quote End --- [/b] --- Quote End --- Hi , kael I met same problem. You need recomplied DE2_NET project again. Regards Faye
The messages
isp1362_hc_reset:clock not ready after 20ms appear since the 2.6.17 kernel driver, the reason is that the reset function is now called and was not with 2.6.11 kernel driver. It does not matter. Why there is a problem with the clock check on De2 Brd needs investigation.
--- Quote Start --- originally posted by faye@Nov 29 2006, 06:46 AM hi , kaeli met same problem.
you need recomplied de2_net project again.
regards
faye
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19685)
--- quote end ---
--- Quote End --- Do you mean simply recomple the DE2_NET project, or does something need to be reconfigured before recompiling? Thanks for the quick feedback.
Hello everyone and thanks for your replies.
Going off what Faye suggested, I found the CD that came with the board that has all of the demonstrations mentioned in: http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux (http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux) I used the DE2_NET.sof from the CD and it works just fine! It seems there is a problem with the file posted in the wiki. Thanks again. - Altera_Forum
is there anyone who knows to do same thing on Windows?
