13 years agoUSB External Chip
Has anyone had any experience with interfacing to an external (to the gate array) USB Chip ? I am looking for a simple, cheap, low power chip that interfaces directly to a NIOS or even better to Internal Memory. I know that there are USB controllers available that will do the job (I am currently looking into an Cycpress chip that has a 8051 controller, and it will do the job, however it might be a little "over kill". We don't need as many features as are offered there in!). We have also investigated a USB-to-serial chip which will also do the job, but we would prefer a direct USB connection.
Anyone got any ideas ?15 Replies
--- Quote Start --- We are about to get a FT232H module in which we are hoping to be able to connect up to one of our current gate arrays. This chip has FIFO 245 interface! --- Quote End --- I haven't used that particular device - but looking at the data sheet, I agree it should work fine. --- Quote Start --- Yes I am comfortable working with VHDL. Are you able to send me your design? --- Quote End --- Yeah, sure. Let me review/clean-up the documentation I'd started, and I'll post a zip file or a link to a zip file. I'll look at it tonight. Cheers, Dave - Altera_Forum
Dear Dave,
--- Quote Start --- Let me review/clean-up the documentation I'd started, and I'll post a zip file or a link to a zip file. --- Quote End --- Did you end in the end manage to make the zip file and documentation ? Are you able to send it to me ? Best regards Shmuel - Altera_Forum
Hi Shmuel,
--- Quote Start --- Did you end in the end manage to make the zip file and documentation ? Are you able to send it to me ? --- Quote End --- Sorry, I have been busy with another aspect of the project I am working on. I plan on using the FT232H on my board, so I will be returning to the code soon. Have you tried writing some code? If you have, and you have had problems, post questions. Cheers, Dave - Altera_Forum
Dave,
Thanks for the reply. Please let me know when you get back to it and if you can send me something to look at. In the mean time I have started on the design myself..... We are considering using the FT2232H chip probably. Have you any good suggestions of how to implement interrutps ? We were thinking of usinging a dedicated endpoint for this purpose (I found out from FTDI they have 2 IN endpoints and 2 OUT endpoints !) Regards Shmuel - Altera_Forum
--- Quote Start --- I have started on the design myself..... We are considering using the FT2232H chip probably. Have you any good suggestions of how to implement interrutps ? We were thinking of usinging a dedicated endpoint for this purpose (I found out from FTDI they have 2 IN endpoints and 2 OUT endpoints !) --- Quote End --- You don't need to do anything at the USB end, that is the point of using these devices :) The FT2232H will show up as two serial ports. Your host code can access them just like it would a USB-to-serial serial port. Under Linux they will show up as /dev/ttyUSBx devices, and under Linux as COM port devices. At the FPGA end, you just need to implement the FIFO interface to your hardware. The SIWU (send-immediate/wake-up) signal can be used to trigger the data to be sent 'faster', i.e., send-now, rather than waiting for a full USB packet to be buffered. Did you order an evaluation kit? FTDI have a module FT2232HQ_mini_module for $27 http://www.digikey.com/product-detail/en/ft2232h%20mini%20module/768-1030-nd/2027252 I haven't tried interfacing to this board yet (I have a module I was given at ESC, but have not had time to test it). I have used the UM245R module, and it was easy to work with. I have a couple of the FT232H modules that should show up in a couple of days. Cheers, Dave
