14 years agoUSB External Chip
Has anyone had any experience with interfacing to an external (to the gate array) USB Chip ? I am looking for a simple, cheap, low power chip that interfaces directly to a NIOS or even better to Inte...
14 years agoYou'll probably need latch the data from the USB parrallel bits and request Avalon master bus cycles based on the latched values.
In some senses a UART interface might make this easier - split each uart data byte into two 4-bit fields, use one as 'command', the other as 'data'. So a memory write would require upto 8 bytes to set the address, 8 bytes for the data and a final 'write' command (which might increment the address, and might set the last data nibble). Read would be much the same except that you'd send 8 data bytes to the host. That would be moderately slow - but probably not impossibly slow! The shared memory access isn't an issue. All the internal memory is dual-ported and the Avalon 'bus' does arbitration.
