15 years agoUrgent HELP!!! RS232 problem
Hi all, I trying to send signal through the RS232 port. I have problem in sending out the integer/character. Below is my code: void serial() { unsigned int a = 0x61626364; cha...
15 years agohi ....
you can change the stdout , stderr and stdin on your nios2 clicking with right button on your design and select system libraty properties (change to your rs232 out)....... if you did that you can use printf to put data on your rs232 thats it Franz Wagner
