11 years ago
Upload Data via NIOS2 Command Shell
Hello, my intention is to read data from NIOS memory (e.g. onchip RAM or SRAM) via the NIOS2 Command Shell. I have running a script and want to read at a special memory address, which is written by the Nios II processor. I think there must be a possibility to "upload" data from the Command Shell, because the "nios2-download" command executes a verify after downloading data to memory. Does anybody have experience with this topic? In other words, I'm looking for a possibility to change information between a running Nios II SW and my script (a simple print to terminal is not helpful). Greetings
    you could use a simple UART-based protocol between your host machine (PC with a skript, or C-Code) and the NIOS.
    The most simple implementation is to use putchar and getchar?!
