13 years agoUpdating Eclipse Project Upon NIOS II System Change
What do you have to do to make projects in NIOS II Software Build Tools for Eclipse pick up on changes made to a NIOS II System in Quartus II/QSYS? I have changed and added components to my system i...
9 years agoIn my version 15.1 it doesn't work ... when I right-click on the project, then go to Index->Rebuild, nothing happens: the system.h file isn't modified and keeps the base address of blocks that are already removed from qsys !
So, how to proceed when changing system composition in Qsys ? Create new BSP in Eclipse ? Is it really no means to update already existing Eclipse project ? Thanks.
