13 years agoUpdating Eclipse Project Upon NIOS II System Change
What do you have to do to make projects in NIOS II Software Build Tools for Eclipse pick up on changes made to a NIOS II System in Quartus II/QSYS? I have changed and added components to my system i...
12 years agoI had the same problem. I found the simple solution:
In the project explorer right click on your NIOS II project and in the popup menu click Index > Rebuild. Now you should be able use newly added defines in system.h file.- GNiaz6 years ago
Thank you for the solution!!! Do you know the reason for that issue?
