13 years agoUpdating Eclipse Project Upon NIOS II System Change
What do you have to do to make projects in NIOS II Software Build Tools for Eclipse pick up on changes made to a NIOS II System in Quartus II/QSYS? I have changed and added components to my system i...
13 years agoAre you sure your application project is pointing to the correct BSP? As long as it includes the correct system.h there is no reason why it couldn't find the constants.
Did you check that the constant names are rigorously identical?
