13 years agoUpdating Eclipse Project Upon NIOS II System Change
What do you have to do to make projects in NIOS II Software Build Tools for Eclipse pick up on changes made to a NIOS II System in Quartus II/QSYS? I have changed and added components to my system i...
13 years agoIf the system.h file is being updated, it sounds like you must be correctly updating the BSP. If not, right click on the BSP -> Nios II -> Generate BSP. That should pull in the changes from the regenerated Qsys system. It has always updated Eclipse for me. Hope this helps...
