Unhooking stdio from JTAG UART
- 3 years ago
Greetings and welcome to Intel's forum.
The Intel-provided driver implements a HAL character-mode device driver that integrates into the HAL system library for Nios® II and Nios® V processors systems. HAL users should access the JTAG UART via the familiar HAL API and the ANSI C standard library, rather than accessing the JTAG UART registers. ioctl() requests are defined that allow HAL users to control the hardware-dependent aspects of the JTAG UART.
As the HAL and JTAG UART are co-related, there is no way to separate both operations and carry out only one of the operations. Here is the link for more information on the JTAG UART IP core with software programming model for your reference: https://www.intel.com/content/www/us/en/docs/programmable/683130/21-4/software-programming-model-16085.html
Hope this clarify your doubts.
Thank you.
Kelly
Any updates from your side? Is there any further help needed from my end?
Thank you.
Kelly
Sorted now thanks. It took some looking to find the customisation settings for the BSP but I turned off the UART drivers and wrote my own.
