12 years agoUnable to run SoCEDSSetup-14.0.0.200-linux.run install app.
I am unable to run SoCEDSSetup-14.0.0.200-linux.run, this is on an ubuntu 3.2.0-63-generic-pae# 95-Ubuntu SMP Thu May 15 23:26:11 UTC 2014 i686 i686 i386 GNU/Linux. I have chmod +x to the file and...
11 years agoDid a complete reinstall of 32 bit Ubuntu 12.04, just in case with all my messing around some wires got crossed.
Verified it is 32 bit from >Settings Installed the update, upgrade, etc. listed under Getting Started with Yocto - Ubuntu 12.04 on the RocketBoard.org page (http://www.rocketboards.org/foswiki/documentation/gsrd131gettingstartedyocto) Did not install the ia32-libs, because as I understand it, it is only needed for 64 bit installs Downloaded the the SoC EDS. Comes as a .run Did a chmod +x, on it, tried to run, (i.e. ./SoCEDS ...), get a "cannot execute binary file" Tried >sudo ./SoCEDS...run , got Syntax error: "(" unexpected From what I can Google, the "(" Syntax error has something to bash vs. dash, so I ran >sudo bash ./SoCEDS...run, and I get "cannot execute binary file" Did a few permutations, i.e. sometimes with ,/, sometimes no sudo, always with bash, but result always "cannot execute binary file". Redid the first few install steps - no difference, because everything already was installed. Tried to install ia32-libs, but would not install ... which I expected. Same with package:i386 Most searched responses have chmod +x fixing the issue. I ran >ls -l and saw that the file attributes had x set. (-rwxrwxr-x) Any advice most appreciated.
