19 years ago
unable to load cramfs
hello friends
i am using cramfs .i have compressed kernel .
i have stored u-boot at 0x0 ,cramfs at 0x00100000 and kernel image at 0x00020000.
my flash is 2MB(0x00000000 to 0x00200000).and sdram is 8Mb(0x00800000 to 0x00f00000).
but when give command " bootm 0x0002000" on hyperterminel then i get o/p on console like:
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6948k/8192k RAM, 0k/0k ROM (883k kernel code, 241k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Linux NoNET1.0 for Linux 2.6
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x80220820 (irq = 1) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
ALTERA map: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using up3 development partition definition
Creating 2 MTD partitions on "ALTERA":
0x00100000-0x00200000 : "romfs"
0x00000000-0x00100000 : "loader/kernel"
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)
    Hi slsnios,
    > atleast ,now kernel is able to find which is fs is there.
    Great!
    > should be not worked when same fs is used as romfs.bin
    You should forget about romfs.bin and just populate the cramfs with the necessary files -- and
    edit the init scripts to suit your own needs. Here's what I typically use:
    d 0700 176 500:245 root
    d 0700 1700 500:245 root/bin
    f 0755 54448 500:245 root/bin/agetty
    f 0755 77640 500:245 root/bin/arp
    f 0755 61804 500:245 root/bin/badblocks
    f 0755 1712 500:245 root/bin/basename
    f 0755 122012 500:245 root/bin/boa
    f 0755 6348 500:245 root/bin/cat
    f 0755 34476 500:245 root/bin/chattr
    f 0755 30976 500:245 root/bin/chgrp
    f 0755 22936 500:245 root/bin/chmod
    f 0755 31200 500:245 root/bin/chown
    f 0755 24464 500:245 root/bin/cmp
    f 0755 26432 500:245 root/bin/cp
    f 0755 12612 500:245 root/bin/date
    f 0755 27156 500:245 root/bin/dd
    f 0755 24940 500:245 root/bin/debug
    f 0755 25500 500:245 root/bin/df
    f 0755 92968 500:245 root/bin/dhcpcd
    f 0755 1536 500:245 root/bin/dirname
    f 0755 1340 500:245 root/bin/echo
    f 0755 111752 500:245 root/bin/ex1
    f 0755 111968 500:245 root/bin/ex2
    f 0755 113920 500:245 root/bin/ex3
    f 0755 112092 500:245 root/bin/ex4
    f 0755 111820 500:245 root/bin/ex5
    f 0755 111828 500:245 root/bin/ex6
    f 0755 112356 500:245 root/bin/ex7
    f 0755 1008 500:245 root/bin/false
    f 0755 58996 500:245 root/bin/fbset
    f 0755 113208 500:245 root/bin/fdisk
    f 0755 27888 500:245 root/bin/free
    f 0755 58340 500:245 root/bin/fsck
    f 0755 107260 500:245 root/bin/ftpd
    f 0755 30840 500:245 root/bin/grep
    f 0755 5820 500:245 root/bin/hostname
    f 0755 25940 500:245 root/bin/ifattach
    f 0755 78852 500:245 root/bin/ifconfig
    f 0755 38292 500:245 root/bin/inetd
    f 0755 23904 500:245 root/bin/kill
    f 0755 29780 500:245 root/bin/l
    f 0755 24224 500:245 root/bin/ln
    f 0755 27588 500:245 root/bin/login
    f 0755 13304 500:245 root/bin/logname
    f 0755 42648 500:245 root/bin/ls
    f 0755 35972 500:245 root/bin/lsattr
    f 0755 2108 500:245 root/bin/mkdir
    f 0755 1728 500:245 root/bin/mkfifo
    f 0755 3820 500:245 root/bin/mknod
    f 0755 26860 500:245 root/bin/more
    f 0755 153200 500:245 root/bin/mount
    f 0755 26968 500:245 root/bin/mv
    f 0755 24216 500:245 root/bin/pause
    f 0755 63200 500:245 root/bin/ping
    f 0755 1536 500:245 root/bin/printenv
    f 0755 36728 500:245 root/bin/ps
    f 0755 4304 500:245 root/bin/pwd
    f 0755 25580 500:245 root/bin/reboot
    f 0755 2164 500:245 root/bin/rm
    f 0755 2036 500:245 root/bin/rmdir
    f 0755 81440 500:245 root/bin/route
    f 0755 88108 500:245 root/bin/sash
    f 0755 54596 500:245 root/bin/sh
    f 0755 21436 500:245 root/bin/shutdown
    f 0755 23096 500:245 root/bin/sigpending
    f 0755 24904 500:245 root/bin/sigsuspend
    f 0755 57332 500:245 root/bin/stty
    f 0755 1096 500:245 root/bin/sync
    f 0755 150584 500:245 root/bin/syscalltest
    f 0755 51976 500:245 root/bin/telnetd
    f 0755 2120 500:245 root/bin/touch
    f 0755 58120 500:245 root/bin/traceroute
    f 0755 1008 500:245 root/bin/true
    f 0755 107144 500:245 root/bin/umount
    f 0755 1892 500:245 root/bin/uname
    f 0755 28256 500:245 root/bin/uuidgen
    f 0755 5208 500:245 root/bin/wait
    f 0755 20392 500:245 root/bin/which
    f 0755 13304 500:245 root/bin/whoami
    f 0755 1356 500:245 root/bin/yes
    d 0700 800 500:245 root/dev
    c 0644 5, 1 0:0 root/dev/console
    c 0644 5, 64 0:0 root/dev/cua0
    c 0644 1, 2 0:0 root/dev/kmem
    c 0644 1, 1 0:0 root/dev/mem
    b 0644 31, 2 0:0 root/dev/mtdblock2
    c 0644 1, 3 0:0 root/dev/null
    c 0644 2, 0 0:0 root/dev/ptyp0
    c 0644 2, 1 0:0 root/dev/ptyp1
    c 0644 2, 2 0:0 root/dev/ptyp2
    c 0644 2, 3 0:0 root/dev/ptyp3
    c 0644 2, 4 0:0 root/dev/ptyp4
    c 0644 2, 5 0:0 root/dev/ptyp5
    c 0644 2, 6 0:0 root/dev/ptyp6
    c 0644 2, 7 0:0 root/dev/ptyp7
    c 0644 2, 8 0:0 root/dev/ptyp8
    c 0644 2, 9 0:0 root/dev/ptyp9
    c 0644 2, 10 0:0 root/dev/ptypa
    c 0644 2, 11 0:0 root/dev/ptypb
    c 0644 2, 12 0:0 root/dev/ptypc
    c 0644 2, 13 0:0 root/dev/ptypd
    c 0644 2, 14 0:0 root/dev/ptype
    c 0644 2, 15 0:0 root/dev/ptypf
    c 0644 4, 0 0:0 root/dev/tty0
    c 0644 4, 64 0:0 root/dev/ttyS0
    c 0644 3, 0 0:0 root/dev/ttyp0
    c 0644 3, 1 0:0 root/dev/ttyp1
    c 0644 3, 2 0:0 root/dev/ttyp2
    c 0644 3, 3 0:0 root/dev/ttyp3
    c 0644 3, 4 0:0 root/dev/ttyp4
    c 0644 3, 5 0:0 root/dev/ttyp5
    c 0644 3, 6 0:0 root/dev/ttyp6
    c 0644 3, 7 0:0 root/dev/ttyp7
    c 0644 3, 8 0:0 root/dev/ttyp8
    c 0644 3, 9 0:0 root/dev/ttyp9
    c 0644 3, 10 0:0 root/dev/ttypa
    c 0644 3, 11 0:0 root/dev/ttypb
    c 0644 3, 12 0:0 root/dev/ttypc
    c 0644 3, 13 0:0 root/dev/ttypd
    c 0644 3, 14 0:0 root/dev/ttype
    c 0644 3, 15 0:0 root/dev/ttypf
    c 0644 1, 5 0:0 root/dev/zero
    d 0700 268 500:245 root/etc
    d 0775 20 500:245 root/etc/config
    f 0664 8146 500:245 root/etc/config/boa.conf
    f 0700 547 500:245 root/etc/group
    f 0664 168 500:245 root/etc/inetd.conf
    f 0664 185 500:245 root/etc/inittab
    f 0664 47 500:245 root/etc/issue
    f 0700 1552 500:245 root/etc/mime.types
    f 0700 308 500:245 root/etc/passwd
    f 0664 1193 500:245 root/etc/protocols
    f 0664 231 500:245 root/etc/rc
    f 0664 113 500:245 root/etc/services
    f 0700 549 500:245 root/etc/shadow
    f 0700 8 500:245 root/etc/shells
    f 0700 12 500:245 root/etc/version
    d 0755 36 500:245 root/home
    d 0700 0 500:245 root/mnt
    d 0700 0 500:245 root/proc
    d 0700 36 500:245 root/sbin
    f 0775 49316 500:245 root/sbin/init
    f 0755 19396 500:245 root/sbin/testapp
    d 0700 0 500:245 root/sys
    d 0700 0 500:245 root/tmp
    d 0700 0 500:245 root/usr
    d 0700 0 500:245 root/var
    --Scott
    hi scott
    here, romfs.bin ...,
    i used nios IDE 5.0 and linux filesystem for generating rootfs folder.
    i gave /<filesydstem project path >/target to mkcramfs for cramfs image.
    but i can&#39;t get you. wher i have to writ and run int script.please tell me detail..please..............
