15 years agoUnable to debug
Hi folks. I have two(2) boards with different Altera components. First one - whith Cyclone III and the second one - with Arria II GX. The board with Cyclone III is OK. I am programming flash and...
15 years agoThe processor not responding at all is usually caused by one of those:
[list][*]bad clock (are you getting the clock from the right pin? If using a pll, are the frequencies correct, is the pll locked?) [*]bad reset signal (the reset input on the SOPC component is active low, while most HDL designs use an active high signal) [*]using a Nios CPU in evaluation mode without a license. In that case do not close the alert box saying that you are in Opencore evaluation (the one with the cancel button) or the CPU will stop answering[/list]
