11 years agoUDP packets via TSE
Hi, I am working on a project that requires me to send data packets from DE2-115 to a PC. since I need a transfer rate in access of 500 Mbps, i decided to do it using Ethernet using Triple Speed Ethe...
11 years agoUSB devices only transmit when requested by the host. This is determined by the OS on the PC. You can get a rough idea by timing how long it takes to copy a large file from a USB drive to your computer.
You could only use a 2nd Ethernet if it is going to a different Ethernet port on your PC. Most hubs just drop packets from other ports while they are receiving from one.
