11 years agouClinux TSE not working
Hello, i have a problem with my Ethernet on the DE2-115 Board using uClinux. When i set up "eth0":
root:/> ifconfig eth0 192.168.14.92 up
eth0 Link encap:Ether...
11 years agoThank you Kazu for helping me! :)
The problem, why my TSE was not working, relays to wrong constrains. My design now is as followed:
module uClinux(
// Clock
input CLOCK_50,
// KEY
input KEY,
// Ethernet 1
output ENET1_GTX_CLK,
output ENET1_MDC,
inout ENET1_MDIO,
output ENET1_RESET_N,
input ENET1_RX_CLK,
input ENET1_RX_DATA,
input ENET1_RX_DV,
output ENET1_TX_DATA,
output ENET1_TX_EN,
// SDRAM
output DRAM_CLK,
output DRAM_ADDR,
output DRAM_BA,
output DRAM_CAS_N,
output DRAM_CKE,
output DRAM_CS_N,
inout DRAM_DQ,
output DRAM_DQM,
output DRAM_RAS_N,
output DRAM_WE_N,
// RS232
input UART_RXD,
output UART_TXD
wire sys_clk;
wire enet_tx_clk_125, enet_tx_clk_25, enet_tx_clk_2p5, tx_clk;
wire enet_gtx_clk_125, enet_gtx_clk_25, enet_gtx_clk_2p5;
wire core_reset_n;
wire mdc, mdio_in, mdio_oen, mdio_out;
wire eth_mode, ena_10;
assign mdio_in = ENET1_MDIO;
assign ENET1_MDC = mdc;
assign ENET1_MDIO = mdio_oen ? 1'bz : mdio_out;
assign ENET1_RESET_N = core_reset_n;
assign DRAM_CLK = sys_clk;
assign ENET1_GTX_CLK = eth_mode ? enet_gtx_clk_125 : // GbE Mode = 125MHz clock
ena_10 ? enet_gtx_clk_2p5 : // 10Mb Mode = 2.5MHz clock
enet_gtx_clk_25; // 100Mb Mode = 25 MHz clock
pll pll_inst(
.areset (~KEY),
.inclk0 (CLOCK_50),
.c0 (sys_clk),
.c1 (enet_tx_clk_125),
.c2 (enet_tx_clk_25),
.c3 (enet_tx_clk_2p5),
.locked (core_reset_n)
enet_pll_90 gtx_pll_inst(
.areset (~KEY),
.inclk0 (CLOCK_50),
.c0 (enet_gtx_clk_125),
.c1 (enet_gtx_clk_25),
.c2 (enet_gtx_clk_2p5),
.locked ()
assign tx_clk = eth_mode ? enet_tx_clk_125 : // GbE Mode = 125MHz clock
ena_10 ? enet_tx_clk_2p5 : // 10Mb Mode = 2.5MHz clock
enet_tx_clk_25; // 100Mb Mode = 25 MHz clock
nios_system system_inst (
.reset_reset_n (core_reset_n),
.clk_clk (sys_clk),
.sdram_wire_addr (DRAM_ADDR),
.sdram_wire_ba (DRAM_BA),
.sdram_wire_cas_n (DRAM_CAS_N),
.sdram_wire_cke (DRAM_CKE),
.sdram_wire_cs_n (DRAM_CS_N),
.sdram_wire_dq (DRAM_DQ),
.sdram_wire_dqm (DRAM_DQM),
.sdram_wire_ras_n (DRAM_RAS_N),
.sdram_wire_we_n (DRAM_WE_N),
.rs232_external_connection_rxd (UART_RXD),
.rs232_external_connection_txd (UART_TXD),
.tse_mac_conduit_connection_tx_clk (tx_clk),
.tse_mac_conduit_connection_rx_clk (ENET1_RX_CLK),
.tse_mac_conduit_connection_mdc (mdc),
.tse_mac_conduit_connection_mdio_in (mdio_in),
.tse_mac_conduit_connection_mdio_out (mdio_out),
.tse_mac_conduit_connection_mdio_oen (mdio_oen),
.tse_mac_conduit_connection_rgmii_in (ENET1_RX_DATA),
.tse_mac_conduit_connection_rgmii_out (ENET1_TX_DATA),
.tse_mac_conduit_connection_rx_control (ENET1_RX_DV),
.tse_mac_conduit_connection_tx_control (ENET1_TX_EN),
.tse_mac_conduit_connection_eth_mode (eth_mode),
.tse_mac_conduit_connection_ena_10 (ena_10)
endmodule
