15 years agouclinux toolchain installation ( cross compiler setting error)
I have just installed altera 9.1sp2 quartusII,nios2eds, nios2-linux-20090929.tar on centOS_5 from InstallNios2Linux tutorial. 1-hen i try to build the binary toolchain (the laptop is i64 architecture but the linux centOS installed is 32 architecture) $~/nios2-linux/toolchain-build/make gcc elf2flt gdb-host the message error is lipthred/linuxthreads.old/wrapsyscall.c:101:error rededfinition of 'msync' ./include/sys/mman.h:97:error: previous definition of 'msync' was here make[1]: ***[libthread/linuxthreads.old/wrapsyscall.o] Error 1 2-then i have installed the prebuild binary tool chain nios2gcc-20080203.tar.bz2 in /opt/nios2/ the cross compiler nios2-linux-uclibc-gcc is in /opt/nios2/bin i can compile the hello.c example also i can do the tryOutuClinux example on 2C35 DE2 kit: configure the fpga with *.sof and run the zimage kernel 3-The problem is when i try continue with the uclinuxDist tutorial: I DONT INSTALL tar -C your_path -xvf nios2-linux-20090730.tar because 20090929 version its installed i do make menuconfig correctly but when i run $../uClinux-dist/ make vendor_hwselect SYSPTF=~/nios2-projects/tryOutuClinux/DE2_NIOS_HOST_MOUSE_VGA.ptf there is an error with the cross compiler selected ---> [candido@localhost uClinux-dist]$ make vendor_hwselect SYSPTF=~/nios2-projects/tryOutuClinux/DE2_NIOS_HOST_MOUSE_VGA.ptf >> error.txt make[1]: nios2-linux-gnu-gcc: No se encontró el programa make[1]: se ingresa al directorio `/home/candido/nios2-linux/uClinux-dist/vendors' /bin/sh: nios2-linux-gnu-gcc: command not found /bin/sh: nios2-linux-gnu-gcc: command not found which: no nios2-linux-gnu-gccbug in (/home/candido/nios2-linux/uClinux-dist/tools:/usr/kerberos/bin:/usr/lib/ccache/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/candido/bin:/usr/sbin:/usr/bin:/usr/local/bin:/usr/local/sbin:/home/candido/nios2-linux/toolchain-build/build/nios2/bin) which: no nios2-linux-gnu-gccbug in (/home/candido/nios2-linux/uClinux-dist/tools:/usr/kerberos/bin:/usr/lib/ccache/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/candido/bin:/usr/sbin:/usr/bin:/usr/local/bin:/usr/local/sbin:/home/candido/nios2-linux/toolchain-build/build/nios2/bin) /bin/sh: nios2-linux-gnu-gcc: command not found make[3]: *** No hay ninguna regla para construir el objetivo `hwselect'. Alto. make[2]: *** [vendor_hwselect] Error 2 make[1]: *** [vendor_hwselect] Error 2 make: *** [vendor_hwselect] Error 2 i have tried $make vendor_hwselect SYSPTF=~/nios2-projects/tryOutuClinux CROSS_COMPILE=nios2-linux-uclibc- but the result dont change 4-¿ How can I configure the cross_compile default? THANKS IN ADVANCE
