15 years ago
uclinux toolchain installation ( cross compiler setting error)
I have just installed altera 9.1sp2 quartusII,nios2eds, nios2-linux-20090929.tar on centOS_5 from InstallNios2Linux tutorial.
1-hen i try to build the binary toolchain (the laptop is i64 architecture but the linux centOS installed is 32 architecture)
$~/nios2-linux/toolchain-build/make gcc elf2flt gdb-host
the message error is
lipthred/linuxthreads.old/wrapsyscall.c:101:error rededfinition of 'msync' ./include/sys/mman.h:97:error: previous definition of 'msync' was here
make[1]: ***[libthread/linuxthreads.old/wrapsyscall.o] Error 1
2-then i have installed the prebuild binary tool chain nios2gcc-20080203.tar.bz2 in /opt/nios2/
the cross compiler nios2-linux-uclibc-gcc is in /opt/nios2/bin
i can compile the hello.c example
also i can do the tryOutuClinux example on 2C35 DE2 kit: configure the fpga with *.sof and run the zimage kernel
3-The problem is when i try continue with the uclinuxDist tutorial:
I DONT INSTALL tar -C your_path -xvf nios2-linux-20090730.tar because 20090929 version its installed
i do make menuconfig correctly
but when i run $../uClinux-dist/ make vendor_hwselect SYSPTF=~/nios2-projects/tryOutuClinux/DE2_NIOS_HOST_MOUSE_VGA.ptf
there is an error with the cross compiler selected --->
[candido@localhost uClinux-dist]$ make vendor_hwselect SYSPTF=~/nios2-projects/tryOutuClinux/DE2_NIOS_HOST_MOUSE_VGA.ptf >> error.txt
make[1]: nios2-linux-gnu-gcc: No se encontró el programa
make[1]: se ingresa al directorio `/home/candido/nios2-linux/uClinux-dist/vendors'
/bin/sh: nios2-linux-gnu-gcc: command not found
which: no nios2-linux-gnu-gccbug in (/home/candido/nios2-linux/uClinux-dist/tools:/usr/kerberos/bin:/usr/lib/ccache/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/candido/bin:/usr/sbin:/usr/bin:/usr/local/bin:/usr/local/sbin:/home/candido/nios2-linux/toolchain-build/build/nios2/bin)
make[3]: *** No hay ninguna regla para construir el objetivo `hwselect'. Alto.
make[2]: *** [vendor_hwselect] Error 2
make[1]: *** [vendor_hwselect] Error 2
make: *** [vendor_hwselect] Error 2
i have tried $make vendor_hwselect SYSPTF=~/nios2-projects/tryOutuClinux CROSS_COMPILE=nios2-linux-uclibc-
but the result dont change
4-¿ How can I configure the cross_compile default?
THANKS IN ADVANCE
    I am sorry,I can not connect with him.He fied that problem one year ago,and maybe he is so busy that he can not come thr forum.
    hello i am with the same problem you had, same computer specs also.
    Can't run this 2 : update
    run ../nios2-linux/update
    can anybody help? Thanks
    Are you sure you were able to do the switch. To me it seems like you are still using the mmu branch.
    Ok, now i am getting an error like "Unable to verify adress between (some adress) and (some adress)" after downloading my image to my board.
    ANy tips?
    You must select test-nios2 branch on uclinux distribution directory and linux-2.6 kernel source directroy too
    cd linux-2.6
    git checkout test-nios2
    cd uClinux-dist
    I've done that,but:
    [root@localhost uClinux-dist]# make menuconfig
    Makefile:63: config.arch: No such file or directory
    make: *** No rule to make target `config.arch'. Stop.
    `config.arch' in the uClinux-dist folder is broken ... !!!
    --- Quote Start ---
    hi Cándido,
    thank you, now I can build the image :D
    --- Quote End ---
    What do you mean build the image, i did the same steps, what will be next step. Sorry for Naive question, I really want to run linux on board
    Iam trying to run uclinux on DE0-Nano board, iam using ubuntu12.04.And iam using nios2-linux-20090929.
    What i did
    cd nios2-linux
    cd uclinux-dist
    git checkout test-nios2.
    In thsese two cases i got "switched to branch test-nios2"
    and i set PATH variable also.And specified hardware architecture
    make vendor_hwselect sysptf=~/uclinux/hardware/de0-nano/simple/de0_nano_sopc.ptf ok only, but when i execute the make command in terminal the error showing as mentioned below
    errorr------------------------------------->>>>>>>>>>>>>>>>>>
    alex@alex:~/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist$ make
    ln -sf staging-pkg-config tools/nios2-linux-uclibc-pkg-config
    rm -f /home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/linux-2.6.x/usr/initramfs_data.cpio.gz
    make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C /home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/../linux-2.6 O=/home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/linux-2.6.x -j4 zImage || exit 1
    make[1]: Entering directory `/home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6'
    /bin/sh: 1: nios2-linux-uclibc-gcc: not found
    make[2]: nios2-linux-uclibc-gcc: command not found
    CHK include/asm-nios2/nios2.h
    perl -I/home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6/arch/nios2/scripts /home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6/arch/nios2/scripts/gen_nios2.h.pl cpu sdram < /home/alex/uClinux/hardware/DE0-Nano/simple/DE0_Nano_SOPC.ptf > include/asm-nios2/nios2.h.tmp; if [ -r include/asm-nios2/nios2.h ] && cmp -s include/asm-nios2/nios2.h include/asm-nios2/nios2.h.tmp; then rm -f include/asm-nios2/nios2.h.tmp; else echo ' UPD include/asm-nios2/nios2.h'; mv -f include/asm-nios2/nios2.h.tmp include/asm-nios2/nios2.h; fi
    GEN /home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/linux-2.6.x/Makefile
    CHK include/linux/version.h
    CHK include/linux/utsrelease.h
    SYMLINK include/asm -> include/asm-nios2
    Using /home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6 as source for kernel
    CC scripts/mod/empty.o
    make[4]: *** [scripts/mod/empty.o] Error 127
    make[3]: *** [scripts/mod] Error 2
    make[2]: *** [scripts] Error 2
    make[2]: *** Waiting for unfinished jobs....
    make[1]: *** [sub-make] Error 2
    make[1]: Leaving directory `/home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6'
    make: *** [linux] error 1
    Kindly Any help?
    the ` nios2-linux-gnu-gcc' is in the folder named `./toolchain-mmu/bin` .i have add it in the file named .profile.but it does not work.
