13 years agouclinux PIO device driver interrupt handler not execute
Hi, Thanks in advance for any help I can get. I have a NIOS2 w/MMU running uClinux v3.7. It's a DE2-115 development kit with Cyclone IV FPGA. I use the PIO megafunction to monitor input rising ...
13 years ago --- Quote Start --- Hi, At first, please check whether the interrupt signal (irq No.2 in this case?) is asserted or not. This check is easily done by using your Signal Tap II. Kazu --- Quote End --- Hi Kazu, You are right about the irq signal isn't asserted. I took a screen shot of the signaltap II (attached) and find out the chip select and input clock isn't either. I use the PIO IP in the QSYS and configure it as follow. clk -> 50Mhz PLL s1 -> clock crossing bridge ->NIOS2 CPU data master bus reset -> clock and jtag reset lines external_connection -> ext_pins The PIO configuration are Width: 1 Input Edge Capture regiser -> Synchronously capture (check) Edge Type: Rising Interrupt: Generate IRQ (check) IRQ Type: Edge Any help is greatly appreciated. Thanks, Yeung
