19 years ago
uClinux installation
Dear all,
I have problem with installation of uClinux 1.4.
I have done following:
1.installed 61_quartus_free.exe
2.installed 61_ip_windows.exe
3.installed 61_nios2eds_windows.exe
4.installed uClinux1.4
All options were set to default.
I am able to run IDE, start new kernel project but when i try to configure kernel or build kernel I get some errors.
Does anybody has any idea what to do?
Thx for reply
    Hey everyone,
    I also had the same problem with V6.1. So I configured a pc with all V6.0
    software and the configure kernel crashed.
    So I ran the scripts from the microtronix installation directory
    (install_cyg_ext.sh and chmod_usr_dirs.sh) and I set the
    environment variable SOPC_BUILDER_PATH_51 to point to the
    V6.0 nios eds installation directory.
    Now the configure kernel did work in V6.0. Even when updating to V6.0 SP1
    the configure kernel stays working.
    I'll hope this will get you further.
    Digi
    --- Quote Start ---
    originally posted by mmlaskac@Jan 24 2007, 03:42 PM
    quartus: 6.1
    ip megacore (include niosii): 6.1
    eds: 6.0 sp1
    hugo, please send me which versions have you tried.
    --- Quote End ---
    I try the QuartusII V6.0 SP1 + NIOSII V6.0 SP1 + Megacore V6.0 SP1
    It is ok!!
    There are some problem by QuartusII V6.1 package.
    I used the QuartusII V6.1 + Megacore V6.1 + NiosII V6.0 sp1 to try but
    is still has problem.
    --- Quote Start ---
    originally posted by mmlaskac@Jan 26 2007, 12:51 AM
    thx to all who response to his forum. it is working now. i am able to configure kernel and download it to flash and run kernel.
    now i have another problem.
    i am able to build romfs but i am not able to mount it. i downloaded this romfs to my flash at offset 0x200000 but from the log it looks like the flash is not recognized, but kernel boots from this memory. can anybody help?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20879)
    --- quote end ---
    --- Quote End ---
    Hi:
    I suggest you to use the flash progeam to download your romfs.
    I guess you use the QuartusII 60 sp1. If you donot use the QuartusII 6.0 sp1 then I cannot help about this problem.
    --- Quote Start ---
    originally posted by hugo_liu+jan 27 2007, 11:57 am--><div class='quotetop'>quote (hugo_liu @ jan 27 2007, 11:57 am)</div>
    --- quote start ---
    <!--quotebegin-mmlaskac@Jan 26 2007, 12:51 AM
    --- quote end ---
    --- Quote End ---
    Hi:
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20935)</div>
    [/b]
    --- Quote End ---
    romfs is in the flash at location 0x200000 and I am using quartus 6.1.
    As I told you before, it be easier to follow the wiki. Many people have their Nios2 uClinux running in a short time with it.
