15 years agouClinux freeze during USB copy - Nios2 nommu - USB Host
Hello, I did a no mmu niosII platform with uClinux booting (test-nios2 branch). I use an Open Core USB Host. I can read and write in a USB Key. But I have a problem. When I copy a file ...
15 years agoHello,
I use 64 Mbytes of SDRAM. I use "cp" to copy from the USB Key to USB Key. I tried with "dd" with different size of blocks. But it's the same. When 20 Mbytes are transfered, uClinux freezes. With the command "free", I saw the field "buffers" : when I make a copy from USB Key to USB key, the size of "buffers" increases but never decreases... I saw that there is an option during the kernel configuration : "kernel log buffer size" but I don't know how to calculate the real size of the buffers. When I make a copy from SDRAM to SDRAM this size dosen't move. Thank you for your help. Best regards. Pierre
