15 years agouClinux 20100621 - conneting NIOS HW with linux
Hi I can not connect NIOS hardware with uClinux kernel. I successfully did it when uClinux support make vendor_hwselect. But when I have to build my custom header file with command sopc-creat...
15 years agoA thing you may omit (if you undestand how, at the moment I couldn't) is the libstdc++.so if you don't need c++ is about 800K uncompressed. Deflating the image would also help you with the oom_killer in the other thread you opened.
The oom_killer is someone who takes care of freeing memory for the kernel by means od killing the other processes. If there are no processes to kill the system will run out of memory.
