15 years agouClinux 20100621 - conneting NIOS HW with linux
Hi I can not connect NIOS hardware with uClinux kernel. I successfully did it when uClinux support make vendor_hwselect. But when I have to build my custom header file with command sopc-creat...
15 years agogood you've found the offset, I completely forgot about it. To deflate the image dimension, try eliminating some applets/applications from Library/Application settings.
