15 years agouClinux 20100621 - conneting NIOS HW with linux
Hi I can not connect NIOS hardware with uClinux kernel. I successfully did it when uClinux support make vendor_hwselect. But when I have to build my custom header file with command sopc-creat...
15 years agoFound it and switched off. Now compilation ends with success. Unfortunataly I get error while downloading Image:(
nios2-download -g images/zImage Using cable "USB-Blaster [USB 1-1.3.3]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: OK Initializing CPU cache (if present) OK Downloaded 3529KB in 20.7s (170.4KB/s) Verifying C1800000 ( 0%) Verify failed between address 0xC1800000 and 0xC180FFFF Leaving target processor paused http://aix.vot.pl/nios/nios_config.jpeg http://aix.vot.pl/nios/cpu.jpeg MMU setting are default When I run on the same project uClinux but cpu without MMU and dual port onchip memory I run uClinux with success.
